filament transformer
When restoring another brand radio, i found a Philco branded filament transformer used to step up 2.5 volt to 6.3 volt.
This radio was originally all 2.5v tubes, but someone had replaced  some with 6.3v types, hence the trannie.
Unfortunately, when i restored all tiubes to 2.v i didn't note how the trannie was connected.
So, can anyone tell me if this was an auto trans or?
It has 3 leads, is wound with heavy wire, laminations 5 cm  x 4 cm x 1.5 cm.
On the top, PHILCO
                  reg us pat off
                32  7019 M
If you restored it back to 2.5V why do you need the transformer anymore?
(12-26-2016, 10:42 PM)morzh Wrote:  If you restored it back to 2.5V why do you need the transformer anymore?
Good question, i want to use it to power a 1.5 v iJ5 tube which is the opt tube in a Zenith 6 J 230, a 6volt or 115 v ac set. all other tubes are 6 volt but the 1J5 has it's filament supplied via two special dial lights (blown) and resistors.
To avoid this i want to use the trans with a rewind and tappings to get 1.5 v.
Rogers Majestic R-646
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 919 online users. [Complete List]
» 3 Member(s) | 916 Guest(s)
