My beater 38-62 project
Hi,
I've posted some before and in-progress pictures on Flickr of a pretty rough 38-62 that I've been working on.
When I got it, it was inop not only due to the electrolytics being bad, but someone had removed a resistor. Physically, the speaker wiring was shot, and the speaker itself had several rips and holes in it. The finish on the cabinet was flaking off, though the Di-Noc panel was in reasonably good shape. Of course, all of the screws holding the chassis into the cabinet were missing, as is one of the speaker mounting "studs".
Getting it to the point shown in these photos has taken a couple of weeks worth of evenings and weekends, not too bad considering the extent of the work. I replaced all the electrolytic and paper caps, most of the resistors, and any bad wiring. I also did cleaned and re-lubed the dial reduction mechanism, cleaned all the controls, and the rest of the usual stuff. The radio didn't fight me at all, it was actually very cooperative, and now plays like nobody's business!
I'm still looking for a few parts for it and need to rub out the lacquer and install the grille-cloth before I call it done, but it's on the bench and playing until then.
I hope someone will enjoy the photos, and I'll post more as time permits. And, If anyone has an extra dial escutcheon and glass for this bugger, please let me know!
Oh yeah, The pics are at: http://www.flickr.com/photos/n8nm/
Happy New Year!
Steve Murphy
Very nice job Steve! Thanks for posting the photos!! Enjoy your vintage Philco!! Icon_wink
Steve: I may have a decent dial bezel. I'll check.
E-mail directly if you want.
Hi Doug,
That would be great, please let me know.
I see you're in Ortonville, so we're practically neighbors (I'm in Waterford). Will you be at the MARC meet in Farmington next weekend?
Thanks!
My Philco 37-116 Restore
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
462ron
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
462ron
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
Arran - I bet you're right probably vinyl, there was no rubber smell when desoldering it, which you often get with the o...EdHolland — 08:23 PM
Ed; It was very likely vinyl covered wire given the vintage of the set, there was some rubber/gutta percha wire used ...Arran — 06:34 PM
