Apex 11
I picked up this 1930 Apex model 11 tonight locally. My interest was sparked when I realized the tube lineup is just two 24s
short of my Philco 90. It has 2 ea. 24, 27, 45 and one 80. With a 12" Magnavox speaker I bet it will sound pretty good. For
$50 I figure I can't go wrong.
[Note from admin - Sorry, photos no loger available.]
I flipped the exterior pic on photobucket so don't ask why it's lying down.
Phil aka Philbert Q. Desenex - Twin Cities, MN
That has to be the biggest of the Apex sets. They were made by U.S. Radio and Television, in Marion, Indiana, if memory serves. That compny later was acquired by William C. Grunow, and was re-named General Household Utilities. The radios were then marketed as Grunow radios.
Both the US R&T and Grunow sets were very good radios. They were not unduly complex, and aleays easy to service. The set will surely sound very good, with those push-pull 45's, driving that Maggie speaker.
Doug, the metal "Screen Grid" tag lists Chicago as the address for USR&T, as does the ad introducing this model in Alan Douglas' Vol.1. However, in his
opening Apex remarks he states that all radios were produced at the Marion plant, so perhaps Chicago is a headquarters address.
The same ad references an eight tube model 115 "high-gain neutrodyne" circuit for the same price with five 27s, two 45s and one 80. I have no idea which
is considered the better outfit.
I am surprised to find the word television in a 1930 company name. I assumed most people were not familiar with the term.
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
