570 Grandfather
I am working on a 570 that I recieved for free. The cabinet was is pretty bad shape with the sides pretty much delaminated. I have reglued and looks pretty good considering. Due to a lot of scratches, and how dried out the finish was, I scraped the entire cabinet. To even out the appearance I wiped on some red mahogany stain.
Questions:
1. The top finial is broken with part of the very top missing. I am planning on turning a replacement but am not sure of the overall length and what the top part looks like. Does anyone have a close up pic or sketch that would assist me? The photo I have from the net is not clear enough.
2. I see a lot of "restored" pics of radios where laquer is sprayed which results in the shiny look (original I believe). Would I be in grave error if I used several coats of a wipe on poly that I am more familiar with. I prefer less shine.
By the way I now have the radio working fine after recapping and winding a coil.
Thanks.
Poly is a no-no if you ever want to sell it and brush on lacquer is as easy as brush on poly and if you want you can wet sand the lacquer to get a nice smooth finish. I don't think I would use poly since I have never found using either spray or brush on lacquer a problem.
Stude is right on the money, marv. Stains will never give the overall uniform color that you get from toning (tinted) lacquer. And for your final coats of clear, you can obtain semi-gloss and satin lacquer as well as the glossy type.
Hello,
I have a 1931 Philco 570 Grandfather clock, but it is missing the radio, the knobs as well as the backlite plate. What would you consider charging to make a clay or plaster mold of your backlite plate on your clock? I'm running out of options to have a reproduction made and finding an existing one is seeming impossible. I'd really like to get something made to at least place in there and I thought about making a mold copy from an existing one. Thank you for any consideration. Layne Chartrand of Troy, Missouri. 314-777-0587.
Hi and welcome, Blackflagger.
Have you tried Old-Time Replications? I believe they reproduce the knobs as well as the escutcheon for your radio.
http://www.antiqueradioknobs.com/
I believe there are other sources for reproduction escutcheons? I know there are other sources for the knobs. Look here:
http://www.philcoradio.com/resourceb.htm
Thank you, Ron! I've not tried for the escutcheon. I did have luck with reproduction rosette knobs at (6.25 each). I will contact them on that. I sure hope they have it; that would be absolutely awsome!!! Thank you so much for the help! Layne!!! This is an EXCELLENT forum!
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1247 online users. [Complete List]
» 2 Member(s) | 1245 Guest(s)
