38-7 Speaker problems
I came across a 38-7 floor model this past weekend. It seems to be in good shape. Except for the speaker. Someone has ripped all of the wires loose. The output transformer is open. And the field coil is ruined, because wires have been broken on the winding. Any ideas on how, or if I can bypass the field coil and output transformer, and still use this speaker. Thanks!
On the transformer check with playthings of the past and see what he has, more than likely he has the correct transformer. On the field coil try your luck at removing the outer cover and see if you can find where the wire is broken at, I have been lucky in the past to find the wire broke or pulled loose near the outer wrapping.
field coil wrapping has been removed. And it looks like many breaks in the winding.
These should be common speakers, Gary at playthings of the past might have both items, he typically is extremely reasonable on this prices. If you can find the speaker part number I will look thought his site and see what he has or you can follow this link http://www.oldradioparts.com/2a32fl.txt
and see what you can match up.
I don't see the speaker listed. I'll email Gary and check. I've got the parts list from Riders 8-66. And there is no complete speaker, just parts. And some of the part numbers are not readable. There is one listed on ebay the looks like the right one. But the seller wants 100.00 obo. Good luck! Ok, if I were to use a pm speaker, what would need to be done to make it work?
On the one on ebay for 100 he is on a planet of his own, these are common speakers so I am sure that Gary should have something or send a PM to Ron and get the correct part number.
Philco Model 249 made in England
It looks like it may have a stereo amplifier, at least for the phonograph section, likely EL84s/6BQ5s, or the series str...Arran — 11:26 PM
Philco model 40-100
That was part pf what began my interest in tube battery radios, the variety of circuit designs, especially by Grimes-Pho...Arran — 02:37 PM
Phill; I had a look at my Riders "Specialized" car radio books yesterday, I don't have one that covers Stud...Arran — 01:50 PM
Thanks for the information MrFixr55.   It's tube amplification and not solid state. TOMfklown — 11:27 AM
Well, I’ll be! I learned something.jrblasde — 11:03 AM
Yes, Garrard was well-regarded for its standalones.morzh — 10:48 AM
Quite the interesting stories, sir! Somewhat reminds me of my first job out of school (not that I worked in a similar fi...jrblasde — 09:33 AM
Philco model 40-100
Arran, I restored 2 Canadian battery-crank telephones for a friend a while ago, a Northern Electric (Canadian version of...MrFixr55 — 08:04 AM
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
There are currently 812 online users. [Complete List]
» 2 Member(s) | 810 Guest(s)
