Which knobs are correct
I have 2 Philco model 70s. One has the large tuning control knob (Rosette Style) and the tone and volume controls are the same style but slightly smaller and the power control knob is simular to the smaller knobs you'd see on the model 21. The other has the same large tuning control knob (Rosette Style) and all the other knobs are simular to the model 21s smaller knobs. So which is original. One of these model 70s is a parts rig. 8)
tractorforum.com *** I reserve the right to be wrong
See the EARLY CATHEDRALS section of my site to help clarify your knob situation.
The 70 had different runs and had a knob change. All documented there.
Chuck
Chuck, I'm still unsure. The graph points to rosette knobs yet the model 70 at the top of the page appears to have plain knobs. The working model 70 I have seems to have the same knob configuration as the model 90 at the top of your page. The parts 70 I have, has all plain knobs, with of course the exception of the tuning knob. So, still not quite sure on this issue. Can you shed more light. Am I reading your graph correctly? By "Rosette" in the knobs column, do you mean all of the knobs, just the tuning not, or?
Like it says in the info, use your set's Serial Number to determine where your set falls on the graph.
That will give your the approximate time frame for the most probable knobs your set would have had from the factory.
Rogers Majestic R-646
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
There are currently 981 online users. [Complete List]
» 2 Member(s) | 979 Guest(s)
