Model 20 case restoration question
Hello,
Can anyone tell me if the model 20 cathedral had toner shading along the edges on the front and sides. The cabinet is a nice walnut veneer and looks great with just a dark walnut stain and lacquer finish but pictures I have seen seem to show a dark shading along the edges of front and sides. If so what Mohawk color and product would be best to add the shading? Dark Walnut? The transparent toner? Thanks for the help.
Charles Yancey
540-649-1403
That would be the correct shading, I think it has some shading in the grille too. it might make sense to use something lighter then extra dark walnut and get it to the right shade in repeated coats. There must be a medium walnut, if that doesn't work use brown mahogany, it won't look reddish with enough coats.
Best Regards
Thanks for the follow-up information. I will try and use a medium walnut and see what that does. I may try and get the dark Mahogany as well. Thanks again!
Charles Yancey
For what it's worth, here's a link to a photo of my DeLuxe 20 with original finish, showing the toning. I can't say if the regular 20 panel is done the same way, but I suspect it is.
[Image: http://antiqueradios.com/gallery/d/47796-2/3philc20.jpg]
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
