1930 Philco transformer question
Hello, I have a 1930 Philco model 77 radio and it needed a transformer which I finally located but when i recieved it, it had 3 red wires where the orignial transformer only had one. The man I bought it from said they were interchangable for a few years but I don't know what to do with the other 2 red wires, where do they go? Other than the additional red wires it is idential to the old one. Help! I don't know what to do... Tom
You might have a power transformer from a Model 76. Part no. 3868. It has three wires in addition to the solder terminals.
Two of the wires are the 110 volt primary winding; the third is the center tap for the high voltage secondary winding (lead "B" on schematic) .
Using your multimeter, you will be able to tell which two of the three wires are the primary leads.
You'll also need to know what terminal is for what purpose. Using the picture below, here is what each terminal is for:
1 - High voltage center tap
2 - Center tap of winding "C" (filament voltage to the 45 tubes and pilot lamp)
3 & 4 - Filament winding for 24 & 27 tubes
5 & 6 - Filament winding for 45 tubes
7 & 10 - High voltage secondary
8 & 9 - Filament winding for 80 tube
[Image: http://i326.photobucket.com/albums/k420/...76tran.jpg]
I can't thank you enough! Your the best of the best! I'm on my way to tackle the situation now. Couldn't have done it without you! Thanks Again!
Information on the Other Front Runners of the Era
It's not  philco but I use it quite often for Marconi radios which are Canadian. It is just another resource for u...Dan Walker — 10:25 PM
Glad to hear the radio is back home. David :clap:David — 08:47 PM
A great ending to the H 725 saga. I would feel all warm and fuzzy. PaulPaul Philco322 — 07:13 PM
Hello everyone!  I've been working on a Philco 38 farm radio with the code 121 version chassis. As you all may know thi...Stormlord5500 — 06:36 PM
PT-6 finished!!
It’s a 1941 model. I won’t be using it enough to justify figuring out. All that’s left is getting the knob I have on or...bridkarl — 06:21 PM
PT-6 finished!!
I have heard of some people adding current limiting resistors ahead of the heater string in AC/DC sets but I never bothe...Arran — 06:16 PM
PT-6 finished!!
the bulb is acting as a current limiter. Sort of a cheap solution to save the rectifer and the power supply filter. I’...bridkarl — 05:49 PM
PT-6 finished!!
Fantastic progress so far! You bring up an interesting question regarding fusing. I don’t hear much about people fusing ...jrblasde — 05:30 PM
New neon bulbs arrived for the radio (and for another project) during last week. I was informed by Mrs H that we were ha...EdHolland — 05:09 PM
No kidding! It’s been raining cats and dogs in Oklahoma today! But the Sun is finally peaking through.jrblasde — 03:59 PM
There are currently 962 online users. [Complete List]
» 2 Member(s) | 960 Guest(s)
