Escutcheon......
I need an escutcheon for a Silvertone 6436 console (1940). The bezel is plastic and quite simple. The one on my radio is cracked. Get on the internet, go to the Portland Antique Radio website, click on the category for escutcheons, a picture of the bezel is on the top of the page (9 1/4" by 5 1/4"). I've found two so far, but both were warped, and, in effect, worse than the one I already have.
CORRECTION: The picture is the eighth one down in the right column.
I also need a propeller dial pointer for a Zenith Y-825. Zenith made this style of radio for many years during the 1950's--all have similar pointers. However, the pointers are not the same--the shafts vary in length.
I need one with a 1 1/4 inch shaft.
Not too much at all! :lol:  Sounds like you’re just dabbling into the hobby!jrblasde — 07:56 AM
Hi Joseph, Fortunately, Ms. Fixr does not read my computer, or she would warn you against coming to me for sanity ch...MrFixr55 — 07:27 AM
48-482 rear panel help
There's a picture of one of the plastic covers in the following thread: I bought a full set of them in 2012 or so fro...klondike98 — 11:15 PM
Good sanity check! You are correct—the first (as in, the most counterclockwise) position is for the push button presets....jrblasde — 11:05 PM
Hi Joseph, First, verify that your band selector is in the correct position for what you want to do. I believe tha...MrFixr55 — 10:59 PM
Got my replacement signal generator in the mail today! I was able to finish alignment of the IF section. I’ve got some t...jrblasde — 09:58 PM
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM
Where is the crack? A cracked tube that has air inside will turn opaque once turned on. Perhaps it is a scratch, nogt a...morzh — 09:50 AM
There are currently 721 online users. [Complete List]
» 2 Member(s) | 719 Guest(s)
