Philco 43 Grille Cloth
This is my first post on the Philco forum. I've been a radio collector since I was 10. This is one of the best radio forums on the internet!
I am looking for a photo of a model 43 that has the original grill cloth, or something very close. The 43 I purchased a few days ago has something that looks a little like part of a black air filter!
Hi and welcome,
http://philcoradio.com/gallery2/1932b/#Model_43B
Something like that. Nowdays there isn't a wide selection to chose from for replacement cloth.
Welcome to the Phorum!
Icon_wave
And it also depends on which 43 cabinet you have.
If it is the 43B cathedral, it originally used the same cloth as Philco 70 and 90 cathedrals.
Thanks for your help!
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
Help with Supreme 599
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM
Rod, Mrfixr55 and everyone else thank you very much for all your help with this radio thus far. Today will be more testi...osanders0311 — 09:26 AM
Thanks for the reply Vlad95. I can't even see the balls let along try to remove them. The grounding forks are going to p...dconant — 08:03 AM
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
There are currently 687 online users. [Complete List]
» 1 Member(s) | 686 Guest(s)
