Info on Philco Model 77
I picked up a Model 77 with two globe 45s in it and they test good.  I'm looking for the "upgraded version" of the schematic that shows all the component values, etc. and any operating instructions for it.  I will be starting a restore on it when I get back from FL in a week or so.
Thanks for any help you can provide.
Joe
http://www.philcoradio.com/images/phorum/schem/77.jpg
Many thanks,  my friend.
Joe
http://philcoradio.com/phorum/showthread.php?tid=16167
The 76 is the same set except it has a local/distance sw vs the 77 which has a tone control instead.
GL
Thanks Terry. This will come in handy.
I think I have an open field coil and both of the windings test open on the audio output transformer. Maybe it is a bad cable connection. Will be checking it out soon.
Joe
Would an output transformer if weak, cause the problems I am seeing with lower B+ voltage? murfmurf — 01:22 PM
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - GaryGarySP — 10:21 PM
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
There are currently 415 online users. [Complete List]
» 1 Member(s) | 414 Guest(s)
