"Blonde" 42-PT95
Hi there guys, long time reader, first time poster...
I've long been a fan of the Transitones. I'm working on a nice little 42-PT95. It's the blonde wood Transitone. I want to keep the original finish, it's in pretty good shape. Just some 0000 wool and mineral spirits followed by a good wood oil and then a couple light top coats of fresh lacquer will have it happy again. My challenge is on the trim pieces and top handle. These pieces have several wear spots on the edges and need to be touched up. It's an ivory to light beige looking color. Has anyone had any experience with these versions of the Transitone? Would Mohawk have something available in a toner lacquer that would work well on these pieces? I'd need real good adhesion with little to no transparency. I'm also wary of using too many coats to build up the necessary opaqueness.
Thanks, Dan
I think you would have to use some form of paint, perhaps overcoated with something. As far as I know Mohawk doesn't cover the blond range.
Best Regards
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1201 online users. [Complete List]
» 1 Member(s) | 1200 Guest(s)
