46-480 FM problem
I'm looking at a restored 46-480 that has no FM. I read somewhere that an open cap in the IF can can do this. So, while I've fixed some IF cans with SMD, I'm not sure how to open this one. I've taken the 2 screws off under the chassis that hold the can. What's next?
All I can see to move is a little protruding tab on one side at the bottom. Is this the secret for lifting the IF can off of the guts? I'm hoping that I don't have to unsolder umpteen wires.
If there is no nut at the top then yes, the tab is the key.
It is much easier to remove the can from the coils inside if the wires are unsoldered and the entire thing removed as one piece. Then you will see a brass piece of metal that goes across the bottom of the IF transformer assembly itself (what you are seeing as a tab - it actually goes across the bottom of the assembly), fitting into two holes on either side of the can. This can be pushed up from underneath slightly, just enough to make it come free. It might be possible to remove this brass piece while leaving the can and assembly in place, but I would imagine it would be rather difficult to do.
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
