Philco 40-150 Electrolytic can replacement
I am working on a Philco 40-150 and am looking for a dummy capacitor to fill in the hole left by a missing 30-2405 cap.  Someone in history replaced the cap and discarded the old cap.   Any source for these?  Thanks.
73's  Bob
eBay is one place though that would be more than one should pay for these. A swap meet would be another. You are in PA, Kutztown is in 1 week.
I did not see anything on EBAY but you are correct the prices can be out there!   Love to hit Kutztown but we always seem to have something else going on.  I can try posing on the Antique Radio Forum as well,  we have some local guys that might have what I need.
73's  Bob
https://www.ebay.com/itm/NOS-PHILCO-30-2...Sw5cNYWJg1
https://www.ebay.com/itm/Lot-NOS-Electro...SwQgpW~-T4
Rogers Majestic R-646
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1076 online users. [Complete List]
» 3 Member(s) | 1073 Guest(s)
