Car radio console?
I cant find it..
Is it even Philco?
Not a Philco. Philco did make two car radio ---radios. An- A361 console and A801 chairside.
Not sure what you have there.
I think the only way your going find much about it is to pull the chassis and have a look at it. My best guess is that it might be made by Automatic. They made a bunch of car radios in '40s-60's. Dial reminds me of them, it tunes backwards.
Wow! Ok, I think I can help solve...or just add to...the mystery, which ever way it goes.
I also have the same cabinet, with a Philco car radio in it! I've owned it for 25 years, and I always thought that it was one of the ones Philco produced during the war, even though I could never find any documentation of that. But mine has some tags in the back...maybe they'll help shed some light?
.pdf Binghamton NY Press Grayscale 1950 - 8594.pdf Size: 973.96 KB  Downloads: 713
Here's the only mention of the Broome Distributing Company, that I can locate on the internet... from 1950.
Philco 60 Squealing
Usually a wave trap is for keeping IF signals from entering the antenna and from leaving the antenna. You feed an IF sig...RodB — 09:30 PM
Philco 60 Squealing
I just peaked it for the best signal at 600. NULL it for IF frequency, originally it would have been null for 500kh...Chas — 08:05 PM
Philco 60 Squealing
Wavetrap no longer matters.morzh — 05:19 PM
Philco 60 Squealing
Rod, I had checked out your suggestions but did not help. I did solder the ground rivets to the chassis as Chas suggeste...dconant — 04:52 PM
37-690 Bass Choke Replacement
Yeah, I know, Mouser and Digikey don't have "big iron" components. For some reason Philco was messing with the...Radiodial — 04:25 PM
Yes, I just had to deal with that while repairing the 37-604 Philco. Exactly that value choke was gone. And the current ...morzh — 03:52 PM
Ah, now where to find one. I've into this before on smaller sets, I now recall. Hammond makes one that is only rated...Radiodial — 03:27 PM
Philco 38-7 Speaker
Ask the admins to put them together. As for the renaming, while inside the thread, you simply press "New reply&quo...morzh — 02:23 PM
This is the parts catalog. 32-7528 choke is 65H, 10mA, 2,250 Ohm inductance. Find a suitable one.morzh — 02:18 PM
While troubleshooting the no bass amplification issue, I think I found the culprit. The choke #104 is reading 164K ohms....Radiodial — 01:42 PM
