Threads: 91
City: Jonesboro
State, Province, Country: AR
In between jobs, I decided to pull a recent freebie I was given, a 38-7 chassis. When changing out the bakelite block, I noticed some of the tar sealer had melted, like it had overheated, possibly from shorting out. This block is directly across the line voltage input. I checked the main transformer. It's supposed to read 120ohms/130ohms to center tap, or 250ohms total. it reads 193/205 or 398 total.
Would you say the main transformer is damaged? I do have another chassis. I may just rebuild that one, and steal parts from this one.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 5
City: Townsend, MA
The transformer apparently isn't shorted or open and probably still within tolerance.
I suggest replacing the line voltage caps with modern X1Y2 types.
Threads: 270
You can pop out the 5Y4 and measure the hv ac from each plate to the chassis. Should be pretty even +/- 5v or so. If that checks ok leave in on for 15min w/o the 5Y4 and check to feel if the transformer gets hot. Make sure your pilot lamp socket isn't shorted.
Threads: 91
City: Jonesboro
(08-09-2018, 06:08 PM)Radioroslyn Wrote: You can pop out the 5Y4 and measure the hv ac from each plate to the chassis. Should be pretty even +/- 5v or so. If that checks ok leave in on for 15min w/o the 5Y4 and check to feel if the transformer gets hot. Make sure your pilot lamp socket isn't shorted.
Thanks for the reminder Terry.
I should have thought of that. I attribute my lapse of memory to a headache I woke up with.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
OK. Paperwork states I should get 315v. I get 331v on both sides. This is with my variac set at 110v. Too high?
Have yet to do the warm transformer test. Will report back soon.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Transformer stays nice and cool after 15 mins.
I'm going to go ahead with finishing re-capping and checking the rest of the chassis.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
OK, so I finished re-capping, replaced out of tolerance resistors, and checked most of the crucial transformers and coils, and did a power-up. No sparks or explosions  .
BUT, it is completely deaf. No static, no reception.
I flipped the chassis over, and started taking voltage readings. Here is what came up:
6K7G:
H: 6.5v
P: 251v/240v
S: 90v/100v
6J5G:
No voltages indicated other than the heater voltage, which checked out at 6.5v
6K5G:
P: 187v/170v
H:6.7v
Here's where I suspect there's an issue. If anyone can give me a clue of where to start looking, I'd appreciate the help.
6A8G:
H: 6.6v
OscP: 113v/180v
P: 141v/180v
S: 78v/100v
I thought the audio cut-off switch on the dial might be corroded, so it was cleaned, and SEEMS to be working, but this type of dial/switch mechanism is new to me. If there's anything I need to clean or check, again, I'd appreciate any tips.
Note: I am getting audio. There is a very low hum coming from the speaker, and touching the grid cap of the 6K5G (1st audio) tube does produce a loud buzz.
Here's a couple pages of paperwork for easy reference:
[Image: https://farm2.staticflickr.com/1835/3015...d8e7_z.jpg]
[Image: https://farm1.staticflickr.com/939/44020...4e60_z.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 270
Ok how about pins 3,4, and 8 or the 6F6.
What happen when you apply a 470kc signal the cap of the IF amp and or the mixer?
(This post was last modified: 08-13-2018, 05:33 PM by Radioroslyn.)
Threads: 91
City: Jonesboro
6F6G:
H: 6.6v
P: 346v/230v
S:258v/250v
Will attempt Signal Gen test momentarily.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
No signal heard when injecting signal to grid cap of either the 6A8G or the 6K7G.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 270
Next step is to inject a 470kc signal thru a blocking cap connected to pin 3 of the 6k7.
If nothing heard inject an audio signal to pin 5 of the 6J5 with the tube removed. If
nothing heard you got something miss wired between the 6J5 and the vol cntrl.
Threads: 91
City: Jonesboro
I think I found the problem. I mis-read the schematic  . The 2.3ohm side of the Ant1-Range 1 is dead  . Fortunately, I have a parts chassis. Organ transplant commencing.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 270
Unfortunately the ant coil/band sw isn't going to effect the IF stage or the det. You should hear the 470kc signal anyway when it's applied the the mixer or IF amp.
Threads: 54
That's the line capacitors, if it shorts out it won't do anything other then blow a fuse, or if leaky heat up and melt tar, it should not harm the transformer primary and definitely not harm the H.V secondary. On this set it's ahead of the power switch, so as long as the set is plugged in it has power across the caps all the time, actually between each side of the power line and the chassis, so it can go without the set even being on.
Threads: 91
City: Jonesboro
(08-13-2018, 06:55 PM)Radioroslyn Wrote: Next step is to inject a 470kc signal thru a blocking cap connected to pin 3 of the 6k7.
Went over the radio and schematic with a fine tooth comb. Couldn't find and mis-wirings. Still no signal or audio on your recommended tests. I connected my iPad using a .1uF cap in line with the tip connector, and the ground hooked to the chassis. This radio is deaf as a post.
Would a bad 6K5G prevent any audio from getting through? It does check out, but it is a bit low, though not excessively.
Would part 29, the audio muting switch be a possible problem? I'm assuming having the switch closed would conduct the audio. If there was a problem with it, is there a way to remove it by rewiring or just disconnecting it?
Blessings,
Jeff W.
Jonesboro, Arkansas
Thank you morzh, that is exactly what I was looking for. Now , is there some where that shows pinouts for Philco power ...Jim Dutridge — 11:37 AM |
Thanks for your help Michael. In fact, this video is only an intermediate result. Later I had to apply another tinting l...RadioSvit — 09:01 AM |
Great job on the cabinet.
PS. In the US notation, "kenotron" refers to specific type of tubes; we call re...morzh — 08:24 AM |
This document has at least some tables of models and parts used.
Example: Choke 32-7572, used in 604 radio.
Search f...morzh — 08:19 AM |
I also checked all the radio tubes on my Hickok 530 tube tester. The 5Z3 kenotron turned out to be faulty, all the other...RadioSvit — 08:02 AM |
Well... While the varnish is drying up, I started repairing the chassis...
Of course I started by replacing the pa...RadioSvit — 07:12 AM |
Hello Martin,
Welcome aboard our little community what great Model 38-7
Sincerely Richardradiorich — 12:30 AM |
Welcome to the Phorum Martin.
I count about 9 paper caps, the 3 electrolytic caps and 2-Y2 safety caps to replace th...RodB — 09:44 PM |
Jim,
We have this index put together by Dale Cook but I don't think that is quite what you are looking for.
The Parts...klondike98 — 09:37 PM |
Yep the dim bulb test is OK but I'd definitely replace all those electrolytics before I did it. Since those #47 conden...klondike98 — 09:18 PM |
There are currently 1043 online users. [Complete List] » 2 Member(s) | 1041 Guest(s)
