Final inspection Nov. 1940
Any advice on a source for a parts list for a PT-2.
Hello. See if this is what you need.
https://www.tubesandmore.com/sites/defau...pg14-1.png
Looks like the same animal KCMike, thanks. Label on the set says PT-2 with no 42 prefix so I wasn't sure and NA lists a PT-2 but it only shows the schematic.
Larry
Found this, hope it helps. David
thank you David
Larry
