Another Alignment Tool
Same here. Very nice. Now, I gotta do an alignment and try this baby out!  Icon_biggrin
Tim
I made the tool I use from a piece of 1/16 inch brass rod. Cut it about 6 inches long, bent over one end about 1 inch from the end to make a handle, ground the other end to a screwdriver point. To insulate just used heat shrink a little above the end, wrapped the handle end with black plastic electrical tape. It's non-magnetic and works great.
Here is an excerpt from an ARRL manual:
http://www.arrl.org/files/file/Technolog...504028.pdf    page 2
So even though iron (ferrous metal) is not used, brass will also detune an inductor.
Russ
