Can you identify?
Anyone recognize this chromed chassis radio?  It's at an auction this Sat. in MI.
McIntosh?
Justa guessing, E.H. Scott, McMurdo, or maybe Craftsman. Tube shields seem different though, and that's the only chrome chassis radios that come to mind right now.
Certainly not a Philco.
I don't recognize it as being any Scott that I have ever seen.  Not all that familiar with McMurdo Silvers, but the ones I've seen looked different as well.  Not at all familiar with Craftsman.
There was also Rogers.
It looks like it might be this one.
https://www.google.com/search?biw=1051&b...5001252558
I have a Wards movie dial console radio, but the chassis is not chromed
Yep, thats what it is... two chrome chassis, two giant speakers... With parallel push-pull 2A3's that thing will thump, but will cost an arm and a leg to replace those tubes if needed...
https://www.radiomuseum.org/r/montgomery_62_197.html
Thanks guys!  this auction is this Sat. about 2 hours away.  Very tempted to go.  A LOT of radios. I really like more complex radios and this one is 16 tubes. Looks like fun. Then again, I have several EH Scott radios that are begging for attention! What's a guy to do?
Buy 'em when you see them and you can always fix them later... You may never see that radio again... Always buy them when you see them if the condition and price are right... It may be your only chance... We know we can get parts, tubes, caps, cloth, knobs, etc. to get them going, but you have to get the radio first...
I have two of them not in the best condition free for the taking if you happen to be passing through central Alberta Canada.
Gregb
I'd love to be passing through Alberta!  Beautiful country.  Unfortunately, I don't see that happening any time soon.
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1002 online users. [Complete List]
» 1 Member(s) | 1001 Guest(s)
