Philco 45C volume control pot question?
So after getting to my last bakelite block to recap, I noticed that the volume control does not have the tap at 75,000 ohms to lower the bass at higher volume levels... it is just a basic 3 wire control pot... They took the 10K ohm resistor and .05 cap in the bakelite block that would have connected to the tap and hooked them to the ground side of the pot... so basically the resistor and cap are doing nothing... It is just wired in like a normal non-tap volume control... Will this affect the performance at all or hurt the radio other than the lowering of bass at higher volume levels? It will not get listened to at a high volume level so it may never get turned up to where this tap would have been introduced into the circuit anyway... Any thoughts?
Methinks that the tap is what creates the bass boost at low volume so low volumes the bass will be diminish w/o the tap. Does it hurt anything nah.
So I may just have little to no bass at lower volume levels with no change as the radio is turned up? That would be fine as I dont think this would put out a lot of bass anyway... Maybe ill search around and see if I can find a different control if I dont like the sound... Thanks, I just wanted to make sure I wasnt hurting anything by not having that cap and resistor in the circuit...
Table radio 51C or 52C?
I think what you may have is another Phactory Phranken Philco, if the holes in the front panel lined up it was not unusu...Arran — 10:41 PM
Ho OSanders, Sorry, I got really busy in May and haven't seen your thread in a while.  I am VERY sorry about that.  ...MrFixr55 — 10:30 PM
Philco 45L Initial Check Up
Dan; I don't think that the model 45 is especially know for coil problems, not that they can't occur for one reason o...Arran — 10:19 PM
Yes, the end with the groove is positive, the stripe with the arrows points to the negative lead. The arrows have minus ...RodB — 09:36 PM
Thank you Rod and Paul I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it.  $5  Unable to fi...antiqueradionut — 05:14 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM
There are currently 347 online users. [Complete List]
» 3 Member(s) | 344 Guest(s)
