Knobs!
Hi, I'm restoring a Model 38-8 (thread below).
One knob from the set I have for this radio has no little inner metal thingy, which holds it onto the shaft (there was, however, some lovely masking tape inside the knob, when I discovered this).
What I need is somewhere to look for a source for cheap surplus knobs, from which I can steal such a little metal tab. Did I mention, "cheap"? Icon_wink
Thanks in advance!
If you have an old box of fuses, the thin metal used for the box can be used to make a makeshift spacer for your knob. You'll have to cut and fold to fit the slot inside the knob, and there will not be any spring action, but it is better than tape.
Heard this from an old timer long ago, and actually, it works.
Find an old wind up alarm clock which nobody wants anmore, take the main (winding) spring out, and cut a little piece of it off. Bend it slightly and fit to replace the missing piece in the knob. You can adjust the tension so you can get the knob on and off normally.
Thanks, all! Will give the fuse box method a try (because I haven't seen a non-working wind-up alarm clock... um, ever! Icon_eek )
Try going to your local building supply and ask for a piece of scrap banding material used to band units of lumber together.
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
