Philco ~ 1942 meets 2009 ~
Something to do with that extra console in the basement ? http://www.youtube.com/watch?v=z4WBTaz4NvY
Not sure if Home Radios is the right category for this, but here it is.
....no comment. Icon_neutral
I used to have a pirate Apple II motherboard, pwr supply, and 2 floppy drives mounted in an old IBM Selectric case. I also put a WE touchtone keypad and network inside a Kellogg wall phone, with cloth covered wiring of course. However, I hope that techno-nerd made sure the chassis went to a good home to enable someone else's console to work as designed.
Dave
Philco 37-116 Cabinet Repair
I think Arran is correct about the substrate expansion. I'm going to give the colored wax a try.dconant — 08:11 AM
Hello Guys, What I would do is get  colors of wax filler and fill in the void ! Sincerely Richardradiorich — 12:41 AM
It looks to me like the structure under the veneer may have expanded from humidity cracking the veneer on the surface. W...Arran — 09:42 PM
Help with Supreme 599
Iam only getting 4vac out of the tranny For the 80 filament. The line rheostat Looks fine and the tranny is getting 11...daveone23 — 08:45 PM
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM
There are currently 451 online users. [Complete List]
» 1 Member(s) | 450 Guest(s)
