I have got a 40-195 that I got from antique strore.I had the chassis out cleaning it and noticed what looks like little electric motors on the tone and volume controls. Are these motors or something else? If they are motors do they turn voulme up and down or what? The tube light up but just makes noise. Is it worth fixing? Thank You for the help Mike
Hi
No, the tone and volume controls do not have motors on them. Each does have a gear on the end of each control shaft; this gear contacts teeth in the tone and volume thumbwheels, respectively. This gearing is what makes the controls operate.
Sometimes teeth break off either the tone or volume thumbwheel, or both. Where the teeth are broken, the thumbwheel cannot turn the control up or down. This can only be remedied by finding another thumbwheel from a junker set. The thumbwheels are made of Bakelite, and the teeth on these can be broken easily if you try to force the control.
Now, as to your other question. Is it worth fixing? That depends. If you plan to fix it up to resell, then no. If you want to keep it and enjoy it, then yes. One man's opinion...
Finally, please do not plug it in and turn it on again until you have, at a bare minimum, replaced the set's electrolytic capacitors and tested the tubes. More info on that subject here.
Help with Supreme 599
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM
Rod, Mrfixr55 and everyone else thank you very much for all your help with this radio thus far. Today will be more testi...osanders0311 — 09:26 AM
Thanks for the reply Vlad95. I can't even see the balls let along try to remove them. The grounding forks are going to p...dconant — 08:03 AM
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
Rogers Majestic R-646
Vlad; It's possible that the tar/bitumen using to pot the box may have lead to the failure of the transformer, either...Arran — 10:28 PM
There are currently 612 online users. [Complete List]
» 2 Member(s) | 610 Guest(s)
