Radio buzzes
I've just finished re-capping and replacing out-of-spec resistors on an Airline Model 62-425 (Montgomery-Ward). I also replaced the Metal clad resistor (R9,10 and 11) with non-metal resistors.
The radio has good sensitivity and plays just fine above 1000KHz. Below 1000KHz there is a persistent buzz that gets louder the lower the tuned frequency. Stations can be heard in this range but with the buzz.
I've tuned the IF and oscillator circuits and I tried moving wires around looking for anything that affects the buzz to no avail.
I welcome any suggestions on how to proceed.
Thank you
Don
If it is tuning-related it is some interference.
Other AM radios nearby do not buzz. And no, the other radios are not on when the subject radio is on.
Don
All the covers have to be on the vibrator section and the radio bottom plate if it uses one. If using a line powered supply the chassis must be earth grounded as short as possible. Vibrator must be in good condition. If the vibrator has been opened and the contact blades bent, the vibration frequency may be off. Should be 115hz.
The buffer cap must be replaced with exact values and type "buffer", no subs of "yellowy" metalized will work in the power supply the metalizing will get blown away because of the spikes. No matter even if using 2.5 kv, the dv/dt is not there unless it is a buffer cap...
If it still buzzes. To prove source is vibrator supply substitute another B+ DC source, an adjustable supply of 80-100 mills, 145 volts. The radio still buzzes look for grounding and/or miss wiring in the RF/IF section...
GL
Chas
Pliny the younger
Morzh,
I rechecked, you are correct that the buzzing is from outside interference.
Thanks, I'll never doubt you again.
Chas,
Thank you for your response. My radio does not use a vibrator; the buzz is from outside interference.
Don
It looks like all the resistors except one are OK. Arran mentioned replacing the sand 150 ohm resistor and mine looks l...klondike98 — 02:25 PM
New find. 91X code 225
Yeah the 121/221 documentation was correct for the RF end of the radio. It left me scratching my head when I was looking...pdieten — 11:59 AM
philco predicta
Hi CGL, Yes, troubleshoot the 140V Power supply, something is definitely loading it down, and since this supply excl...MrFixr55 — 07:32 AM
1934 American Bosch 440T restore on YouTube
Looking forward to Part 2.Jimradio — 07:30 AM
Yeah, looks really dense. It is amazing how many sets of brand A were made by Brand B. I have Mid 50s RCA that is an e...MrFixr55 — 10:15 PM
Philco 60 Power Trans
I am not 100% sure of the reason, likely due to the depth of the winding, but on HV windings of a power transformer and ...MrFixr55 — 10:04 PM
46-1213 Schematic Question
Hi Larry, Great idea on the fuse!  Place in the line at the power switch.  Best between the cord and switch.  While ...MrFixr55 — 09:59 PM
Philco 47-205
Just picked up the second of the three Leatherette Philco's. (My second one in the three-radio series) Nice shape, all p...slford310 — 09:18 PM
Dan; I take it that you mean that the H.V winding reads 157 ohms on one side of the center tap, and 177 ohms on the o...Arran — 07:00 PM
Hello, I have a Philco 91 code 121 (one speaker). I found more info here that might be of some help. Might want to fo...dconant — 06:42 PM
