Dial removal, 37-675
How does one remove the dial from the 37-675? This is the preset dial mechanism that was also used on the 37-690, 38-690, and the 38-1. I just picked up one of these console rather cheaply and it's in near perfect condition except for the grill cloth.
Pete AI2V
Pete AI2V
Hi Pete
I was going to scan Bulletin 273 for you, which gives complete information on the Philco automatic tuning mechanism and how to remove the dial scale, etc. However, I see Chuck has already done it; so rather than duplicate his work, allow me to direct you to his website:
http://www.philcorepairbench.com/autodial/index.htm
There are four links at the bottom of that page, which are the four pages of Bulletin 273 in PDF format. You should download and save all four for future reference.
Rogers Majestic R-646
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 930 online users. [Complete List]
» 3 Member(s) | 927 Guest(s)
