Pioneer SX-1500TD lamp circuit
I'm working on a Pioneer SX-1500TD receiver and noticed that Ron Ramirez had posted a thread about his rebuild (a long time ago).  Hey Ron, or anyone else, can you help me on a problem I'm having with the lamps?
I replaced them all and everything worked fine, but then I accidentally shorted something and they all went out but the receiver is still functioning properly.  The lamps themselves are not burned out--theyr'e still good.  But I can't figure out from the service manual diagrams where the problem is.
Hello and welcome. If you have not found the problem yet follow the blue wire that comes out of the transformer.
It will go to a terminal strip right next to the transformer. There is a glass fuse there covered in plastic and soldered in.
You could use a jumper wire across the fuse to see if the lights start working.
Late last night (after posting) I found that fuse.  I don't think it's on the schematic, so I was surprised to find it.  It was indeed blown, and using jumpers the lights indeed came on.  Soldered it in this morning and everything seems to be working.  Except the STEREO INDICATOR itself, but I'm not really worried about that.
Thanks for your confirmation.
You can get the manual for that receiver here:
https://www.hifiengine.com/manual_librar...00td.shtml
You have to create an account to download (it's free).
The stereo indicator lamp not working could be caused by one of two things: either a burned out bulb, or a problem with the receiver's FM MPX decoder. Does it receive FM broadcasts in stereo?
Yes, it's receiving stereo FM very well.
Ok. As I recall the lamp is incandescent, so you have to do one of two things: one, replace with an identical incandescent bulb; or two, replace with an LED but you will have to add series/parallel resistance to make the MPX decoder "think" it is incandescent.
Or do as you mentioned and just leave it alone. I would not do that, however - I would want a working bulb.
thanks
Model 96 cabinet veneer
I can't figure out what the first step is, let alone the final step. I have tried copying pictures from my hard drive a...TGLager — 01:40 PM
Philco 38-2 Low Volume
I managed to get some more time on this. Hi Mr. FixIT, The radio has been recapped. Many of the resistors were rep...dconant — 01:39 PM
Thanks guys for the help. I started looking at these points but I have to quit for the day. I will be looking into this ...dconant — 12:23 PM
RCA WV-98c
Check out this crazy zero pot operation. Touching it drives it crazy. Its rubber tipped. Also the 6al5 has no negative v...daveone23 — 12:08 PM
If you check all of that and still have a problem (my first inkling would be one of the 6F6s) then look at the 6J5 phase...RodB — 10:44 AM
RCA WV-98c
Those will probably depend on teh switch combination. Could you list some that you see, their values and what they sh...morzh — 10:26 AM
You are probably skipping the final step. Once you select the photos you want and they get downloaded, the system assign...RodB — 09:36 AM
RCA WV-98c
At this point, there is no input, just internal voltages Which are incorrect and not sure what they should be.daveone23 — 09:15 AM
Hi DConat, Generally, the lower the plate voltage the less negative the grid voltage has to be. Since the plates an...MrFixr55 — 09:27 PM
RCA WV-98c
If I had it in front of me, I would triy to trace the signal on one of the non-working functions. Try to trace and high...morzh — 08:21 PM
There are currently 1232 online users. [Complete List]
» 1 Member(s) | 1231 Guest(s)
