Heathkit Sb-102 150 Volt problem
All, I seem to have a problem with the +150 Volt supply..I found the 1K 7 watt resistor open I replaced it and turned the radio on I then smelled something burning the resistor again had opened.. so question is what does the + 150 volts feed? must be something either shorted or drawing a lot of current..
This is in RX mode My HV 800 Volts are good and also the +300 volts The bias voltage manual says -111 I read -124..
Skip
