Repairing a beam-of-light turntable
I have a philco 42-1012 console which I have been slowly fixing over a number of years. I heard a restored 42-1012 playing a 78 on you tube and was very impressed with the quality of the sound so I decided to start working on mine again. The bell idler on my beam-of-light has a flat spot and is cracked .So I need to get my idlers repaired and I'd like to know who does the best job of repairing them?
I believe West-Tech Services has developed a replacement rubber piece for the bell drive idler.
http://www.west-techservices.com/
Well, I took the turn table apart , cleaned and oiled it up. I took the idler wheels off and sanded them down a bit. So now the record changing is functional and quiet. I found two burnt out bulbs the one for turn table speed and the beam-of-light bulb. I had an incorrect bulb to replace the beam-of-light bulb. So I could test the light sensor and it was putting out .042 volts. I tried a playing a 78 and got no sound. I checked the needle/mirror assembly and found rock rubber bushings. Worst I found the needle tang was only loosely attached the to mirror and could be wiggled about 45 degrees. So I rigged up some new bushing and epoxy-ed the needle tang back on to the mirror. So I tried playing a 78 again and I still got no sound from 78 but I did get a loud hum from my work light. I've owned this console for over ten years and I've totally re-capped it. It plays well but I'll have to wait and see if West Tech has replacement bulbs before I can get the phonograph to work.
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set war...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
There are currently 870 online users. [Complete List]
» 2 Member(s) | 868 Guest(s)
