11-10-2020, 04:40 PM
Can someone explain this? Does the screw on the spider limit the movement of the voice coil?
[Image: https://i.imgur.com/PieaQRW.jpg]
Current limiter in a speaker?
11-10-2020, 05:25 PM
Could it be part of a repair, where that particular part just happened to fit the bill?
11-10-2020, 05:32 PM
It appears that someone used a panel control label as a washer. The screw is to allow the voice coil to be centered around the magnetic pole. Can't see how a mechanical fastener would have any connection to vc current. Maybe someone else will have more to say. Maybe the screw kept coming loose from all the bass notes.
11-10-2020, 06:48 PM
Yeah that's what I think. A piece of something just fit.
11-10-2020, 08:36 PM
So, it looks like the consensus is a broken spider. I went ahead and bought the speaker, so I'll know more when I get it. Might be able to replace the spider without reconing, I hope. Or maybe do nothing if it works the was it is. Seller says field coil is O.K.
I thought maybe this might have been one of those rare engineering experiments.
« Next Oldest | Next Newest »
Users browsing this thread: |
