39-6173 Bakelite
I am a complete novice here and have one Philco radio with 39-6173 on a sticker on the inside of the cabinet and AX16093 stamped on the chassis.
I'd like to know what I have. Picture below.
Thanks...and if I need to do some remedial reading, just point me to the sources.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Hi William, and welcome!
The "39-6173" number you see is the part number of the tube layout sticker; it is not the model number of your radio.
The correct model number is TP-52. These were also advertised as Model UA-52P.
This radio was also marketed under the Simplex name. I suspect Simplex probably designed the set.
Has the part of your radio that is red been painted? The TP-52 was advertised as being made of white Beetle with a black base. The only photo I have ever seen of one is in a white/black color scheme.
At any rate, that is a really cool little set.
I sent you a PM on this subject.
The red color appears to me to be original. The unit has some chips and underneath the red is black. I see no white on it at all.
A handwritten message on the top of it makes note of the University of Georgia whose colors are red and black and is dated 1940, apparently contemporaneous with a UGA football game. Would this have been manufactured in 1939?
Thanks for the info.
Hmmm...very interesting. So now a color variation to the TP-52 has been confirmed.
Yes, it would have been manufactured around the summer of 1939.
Nice find!
Edit: I should add that those knobs are not original to the set.
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
There are currently 1111 online users. [Complete List]
» 2 Member(s) | 1109 Guest(s)
