Philco 37-620
Hi guy's,
Replaced all caps and some resistors, tested all tubes. The problem I have when I turn it on after a few seconds it will have some static and cut in and out (the sound) just for a few more seconds. After about 20 or 30 seconds it will play great with no problems. I did replace the 5Y4G no improvement. What should I look for.
Jim
Spring Lake MI
Hi Jim,
Try pulling tubes start with last If if static disappears you know it’s probably coming before, if it’s still there you probably know it’s in the audio or power supply.
Forrest
Check for cold solder connections.
Also on this radio volume control has a flat spot or very low audio about half way thru the control. Can this be repaired or would it need a new control.
Jim
Spring Lake MI
Need some help on this..........
Jim
Spring Lake MI
Just replace it. Not worth the trouble and it won't last.
Thank you I have one on order today from Old Radio Parts.
Jim
Spring Lake MI
There are currently 1481 online users. [Complete List]
» 2 Member(s) | 1479 Guest(s)
