11-16-2021, 08:45 PM
It's been discussed many times..but..
My 20 has the 1 1 1.5 and .13.
I used the 20a values os 2 2 1.5 and .47.
The original can was still in spec with one cap measuring .8 instead of 1.
Normally going over a bit makes for less hum..but others have mentioned higher voltages for this early power supply..that and the choke..field coil etc..it seems finely tuned.
Most who add higher values do 4 6 8 or 10.
I uses the 20a values good for 25-60 hz.
That said should I open the can ans replace the 2 with 1 etc...
Thoughts? Will using 20a values raise the voltages that much? Hum was minimal before rebuilding cap can. I have not tried it as speaker is getting reconed.
