OSCILLATOR
My set philco 111 . Will quit receving anything . So i decided to check oscillator plate voltage good 65 volts . decided to check other voltages
touched wire from oscillator plate to osillator coil started working . It will play for hours turn off have to do this almost every time.
I left cover off so i can touch this connection . What do you think strange i know . But this set has been a pain from the get go. Icon_mad
Any ideas Thanks Kent.
Possibilities and things to try:
Bad tube cap maybe. Try a known good tube.
Have you re-capped the set?
Bad tube socket.
Bad/cold solder joint.
Bad cap or resistor no replaced.
Intermittant continuity in the osc coil. (VERY common for Philco coils to be open due to corrosion in trhe windings or right at the solder lugs.)
The coil form could also have moisture in it.
Also check your oscillator tube, a type 27.
Chuck has already mentioned the most likely possibility: intermittent continuity in the oscillator coil, which calls for a rewind.
Information on the Other Front Runners of the Era
No kidding! It’s been raining cats and dogs in Oklahoma today! But the Sun is finally peaking through.jrblasde — 03:59 PM
Philco Battery-WWII vintage
While a kid, in our garage there was a 12V Lead-Acid battery from T54 tank. This job was probably 150 lbs or so, ad was...morzh — 03:54 PM
PT-6 finished!!
All recapped and checked. Had to order a new knob. Seems to work ok. The bulb seems to be an issue. It’s bright for a...bridkarl — 03:48 PM
39-116 in the movies
In 1935 thru 1947 MGM made a bunch of short subject (abt 20 min) under the title of Crime Does Not Pay. It also was a ra...Radioroslyn — 03:10 PM
The Radio Archives has a very extensive library of photos listed by manufacturer, it can be helpful to find a model if y...Paul Philco322 — 01:00 PM
Scaled to the persons foot in photo safe to safe that's a big one. I am sure there was all kinds of war materials they ...Paul Philco322 — 12:54 PM
We received an inquiry from a metal detecting group who was at a WWII site. They unearthed the Philco battery you see i...klondike98 — 12:03 PM
Good morning, folks! I’ve got a question. We have such a wonderful resource as philcoradio.com for service manuals, gene...jrblasde — 10:51 AM
Philco Model 249 made in England
It looks like it may have a stereo amplifier, at least for the phonograph section, likely EL84s/6BQ5s, or the series str...Arran — 11:26 PM
Philco model 40-100
That was part pf what began my interest in tube battery radios, the variety of circuit designs, especially by Grimes-Pho...Arran — 02:37 PM
There are currently 1259 online users. [Complete List]
» 2 Member(s) | 1257 Guest(s)
