41-608. 121 bol
Well  I been away to long
Decided to work on my 41-608 122
It worked before I changed caps
Even after I changed electorlyitics
Now I changed paper caps   But not the 1000 volt caps   now nothing dead   At my Veriac 120 v
But at block and on off switch has 7v. Even if I jump switch out
Thanks sam
If you don't have it at the switch. Check your cord and plug. That set is a little odd as the switch is before the block most are after.
Thanks Terry
Plug was not making good contact in my veriac
Plugged it in wall now working
Thanks sam
HI SAM!
HI Sam Icon_wave
