turn the philco 53 707 into a lamp radio
i just aquired a philco 53 707 clock radio at the top is a factory hole for a lamp.inside the radio is a sticker that states to use only a philco lamp attachment. so my question if i do put a lamp on this set will it effect the value much .i know you purest might throw up at the thought however it was made to have a lamp. thanks for the info
I just looked this set up.
Models 53-706 and 53-707 are identical except for the cabinets, and the fact that the 706 came from the factory with the lamp while the 707 did not.
You might lower the value slightly by adding a lamp to the 707, but right not these are not really "hot" collectibles so I say it's your radio, use the factory hole for a lamp if you wish since the manufacturer apparently gave that option to the original owners. Icon_smile
thanks ron ,do you know where I can find a picture of one colored so I can restore it to original state again thanks for your time
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:25 PM
Testin a speaker and output transformer Trutone A2-G
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:24 PM
Save the money on the Kapton tape. Just cut an insulator to size out of a clear plastic blister pack and attach it arou...GarySP — 01:13 PM
The thing is when I touch or probe the antenna terminal, the volume control input, the wiper (output), and the primary t...Stormlord5500 — 12:53 PM
Two small radios from France. Restoration and review.
Hello, Vlad. I agree with your description of French radios. I might add that they are made like French cars – extravaga...RadioSvit — 11:08 AM
I do thank you all for helping me out on this.Stormlord5500 — 08:01 AM
It does oscillate. Here's the deal. If I touch a probe or my finger to anything in the secondary circuit of the antenna ...Stormlord5500 — 08:00 AM
Hello Arran, Some great info so you are talking about silver migration then that seems to really play issues with these...radiorich — 02:43 AM
Hi Stormlord and welcome to the Phorum. I am scratching my head because, even if the primary of the antenna coil is b...MrFixr55 — 01:56 AM
You do not have to use Kapton: buy a bottle of fabric glue and simply put a thick layer to fix the turns.morzh — 04:04 PM
There are currently 2109 online users. [Complete List]
» 1 Member(s) | 2108 Guest(s)
