Can anyone Identify this radio
Greetings,
It has no identifying marks on it anywhere. A few of the tubes say philco. But I dont recognize it.
Any help would be appreciated.
Cheers
Current Restorations In Process
RME DB22A - Lafayette KT200 - Hammerlund HQ 140 XA
Johnson Viking II - Viking VFO 122 - Johnson Ranger
Philco Model 90 Low Boy
I got stuff.... and things.... and I never said I could spell!
If it is not an Echophone, then it is a Peerless.
Heres a shot of the Chassis....
Quote:If it is not an Echophone, then it is a Peerless.
Still not seeing a match with those either... but thanks!
Cheers
Im begining to think someone used a Peerless reproducer cabinet to house another RF deck of unknown origin.
It clearly seems its a Peerless cabinet.....
Cheers
I think it is an Echophone or similar chassis in the Peerless speaker cabinet.
Would a Peerless speaker be deep enough to house a chassis? It's not an Echophone cabinet because there is no lyre (sp?) On the grill.
The chassis almost looks like an Aztec by Fred Stein, but it isn't painted black and doesn't have the brass sn tag.
Heres a shot under the chassis.
It is an odd case isnt it??
Cheers Icon_smile
John
The Grill and the shape of the cabinet are 100% Peerless speaker.
Whether they deepened it to house the chassis....good question.
It is a Franken Radio for sure.
What are the tubes currently in the chassis? Interesting that the one tube socket on the far right is installed with screws while the other 4 are riveted. Stuffs been done to this radio. Take care and BE HEALTHY! Gary
Quote:What are the tubes currently in the chassis? Interesting that the one tube socket on the far right is installed with screws while the other 4 are riveted. Stuffs been done to this radio. Take care and BE HEALTHY! Gary
Left to right - 24A 24A 24A UX245 80
Cheers Icon_smile
Another photo of the top..
I took that tube list to Antiqueradios.com and got 8 hits for a 5 tube radio, none that look like a match. Looks like you have a chore to Name That Radio!
Thanks to all who helped.
Really appreciate it.
Cheers!  Icon_cool
Model 96 cabinet veneer
I can't figure out what the first step is, let alone the final step. I have tried copying pictures from my hard drive a...TGLager — 01:40 PM
Philco 38-2 Low Volume
I managed to get some more time on this. Hi Mr. FixIT, The radio has been recapped. Many of the resistors were rep...dconant — 01:39 PM
Thanks guys for the help. I started looking at these points but I have to quit for the day. I will be looking into this ...dconant — 12:23 PM
RCA WV-98c
Check out this crazy zero pot operation. Touching it drives it crazy. Its rubber tipped. Also the 6al5 has no negative v...daveone23 — 12:08 PM
If you check all of that and still have a problem (my first inkling would be one of the 6F6s) then look at the 6J5 phase...RodB — 10:44 AM
RCA WV-98c
Those will probably depend on teh switch combination. Could you list some that you see, their values and what they sh...morzh — 10:26 AM
You are probably skipping the final step. Once you select the photos you want and they get downloaded, the system assign...RodB — 09:36 AM
RCA WV-98c
At this point, there is no input, just internal voltages Which are incorrect and not sure what they should be.daveone23 — 09:15 AM
Hi DConat, Generally, the lower the plate voltage the less negative the grid voltage has to be. Since the plates an...MrFixr55 — 09:27 PM
RCA WV-98c
If I had it in front of me, I would triy to trace the signal on one of the non-working functions. Try to trace and high...morzh — 08:21 PM
There are currently 1235 online users. [Complete List]
» 1 Member(s) | 1234 Guest(s)
