39-6CI
I pulled the chassie out of my 39-CI[also found 39-6CI on the bottom of the cabinet so it was originally painted] I was surprized to find it is not a AC/DC set ,it has a little power transformer with tube filaments not in series, and 215volt "B" voltage! seams to be a expensive way to build a cheap radio?
Yep, the 39-6 is an AC-only set with a transformer. Did you also notice that the wires coming out of that transformer are, like the rest of the wiring under the chassis, insulated with rubber? Icon_eek A disaster just waiting to happen.
Philco wised up in summer 1939 and went back to cloth-covered wires for their power transformers in the new 1940 models. Too bad they did not go back to cloth on the rest of the wiring.
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
Meter is a DMM (Brymen BM-257 to be exact) Voltage being measured to the chassis Yep, just double-checked 'emsq65 — 10:22 AM
There are currently 802 online users. [Complete List]
» 1 Member(s) | 801 Guest(s)
