Shawdowmeter on a Philco 91
The shawdowmeter on my Philco 91 chassis works but when tuned to a station the vertical bar on the front of the lens is much too wide. Does anyone know how to correct this problem. Thanks for any and all help.
Floyd
Have you given your 91 a good alignment per factory specifications?
The older shadowmeters are basically not adjustable; you can only bend the lamp bracket in back to center the shadow on the screen. Usually when the shadowmeter does not respond well to changes in signal strength, it is an alignment issue. Occasionally it is caused by a sticking vane. Some of the older shadowmeters do have a (very tiny) screw adjustment inside the shadow box to loosen/tighten the vane.
Be extremely careful if you attempt this. It would be very easy to screw the shadowmeter up while you have it open, especially if you get overzealous with the screw adjustment. Also, be aware the metal tabs on the bottom may very well break off; the thin metal is very old, very thin, and very fragile.
Ron,
Thanks for the reply and info. Yes, I have aligned the set according to factory specs. I have also searched my Philco factory data hoping to find an answer to my problem but to no avail. In my younger years I would have attempted to disassemble the meter and checked the vane. etc. Now at 78 years of age, I'm afraid this would be too tedious a task to try. I will attempt to adjust the distance of the pilot lamp by bending the bracket. Your help, concern and endeavors are much appreciated.
Floyd
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
Meter is a DMM (Brymen BM-257 to be exact) Voltage being measured to the chassis Yep, just double-checked 'emsq65 — 10:22 AM
