RCA shortwave radio Model 40X ?
Threads: 2
City: Venus
State, Province, Country: TX
Howdy folks,
I don't post here as I enjoy reading and learning from you all and don't want to be a pest asking dumb questions. Having said that today I came across an older radio without brand name up front just a Model 40X in the back. There's also a smaller label on the back saying "Licensed only for radio amateur under experimental and broadcast reception" Patents under Radio Corporation of America HAZELTINE AND LATOUR AND AFFILIATED COMPANIES
I assume radio was produced by RCA for ham radio operators but can find absolutely no info about it on line. Can anyone here help me find some info about it? Thank you in advance.
My first experience working on the radio was shocking  but I am getting used to it.
Threads: 8
City: Roanoke
The patent licensing notice has no relationship to who manufactured the radio. I don't see a model 40X in the Universal Schematic Locator or in the CD-ROM edition of Bunis. It isn't one of the 1939 RCA series which begins "40X" followed by two digits.
Threads: 47
City: Roseville, MN
Dale is correct. RCA owned the patent for the superhet design and licensed the design to any company with the right compensation. This notice had to be attached to every radio under the license agreement. Sarnoff was not a hospitable person.
This appears to be a post-war model as pre-war radios with phono jacks were rare.
Threads: 269
Is this a set that you saw or a project? If you have it there is a way to look up the tube lineup and try to figure it out that way.
I'm a little iffy on the 1st IF trans and the pushbutton assby but I'm a pessimism.
Threads: 2
City: Venus
Hi,
I do have the receiver at home on the workbench. Didn't want to mess with it too much without prints/schematic but I guess now I'm gonna have to. Additional detail radio came from a military gentleman from Hawaii who was a radio collector.
Threads: 269
Your chassis is a bit different in that it uses both standard base and octal base tubes. I would think that it would be a pre war set but we'll see. Here's something to try: https://grillecloth.com/sylvania/tubelist.php
(This post was last modified: 05-21-2024, 04:21 PM by Radioroslyn.)
Threads: 32
City: Wellborn Florida
Thinking about your set maybe it started life as a kit. Looking at the push buttons and the screws on each side. Found a set years ago at a flea market the only markings personal radio. Had wood blocks to align the parts. link to my post. David https://philcoradio.com/phorum/showthrea...#pid151851
Threads: 54
For a start, the layout, and chassis design does not look like an RCA model, also RCA wasn't really in the habit of mixing tube types with different bases. Given the electric pushbuttons that would make the set 1938 or newer, more likely 1939-40 or newer, which if it were an RCA set would mean it would have an RCA jack and not a pair of pin jacks, and more then likely included a magic eye tube. I'm not sure when the RCA jack debut but it may have been around 1937, the 1935 and earlier models had a pair of screw terminals, none used pin jacks like an old set of headphones.
I do not think that this was a kit, if it were then why would it have "Tested by #11" stamped on the back apron? It looks like something made by one of the Chicago independents, Belmont, Continental Radio and Television (Admiral), Sentinel (though the chassis doesn't like like one of theirs). It's not a Crosley, I don't think it's an Arvin, or a Detrola. It could have been made by Colonial, which was in New York state, they used to make stuff for Sears.
Threads: 32
The push buttons just do not add up. Looking from the back of the set me thinks not part of the set when it left the factory. David
Threads: 47
City: Roseville, MN
David, I think you're right. When leaving the factory it would have a bezel around the buttons. It's a strange one.
Threads: 120
City: Omak
State, Province, Country: WA
Hello Rob,
I think the bezel around the buttons is just missing because you can see where the wood is a different color where bezel was covering the wood !
Threads: 32
Looking at the push buttons and the knobs just do not match to my old eyes. David
Threads: 31
City: Lapeer
State, Province, Country: MI
It would be helpful to know the tube line-up.
Joe
Hello Jeff ,
Far as the Electrolytic capacitors go here is a list of parts.
that will work . I like using Nichicon and...radiorich — 09:50 PM |
Well, I've been stumped at trying to get the first of 11 electrolytic capacitors. I got a schematic and have a list of t...Jeffcon — 07:54 PM |
Thanks Gary and Rod.
I also found an article in the Philco Repair Bench under Service Hints and Tips, about installi...Hamilton — 12:32 PM |
Hello Hamilton, here is a little information found in our Philco Radio Library at the bottom of the Home page. Hope it ...GarySP — 11:28 AM |
I did as you suggested and touching the middle of the volume control did nothing so the coil has to be rewound. Any idea...Hamilton — 10:19 AM |
This would be the second portable in the "other radios" forum where I have a similar one in my collection. I h...Arran — 12:41 AM |
Hi PittsburgTost.
The record changer looks like a Garrard or BSR (Likely Garrard). The spindles just pull out and pu...MrFixr55 — 11:57 PM |
Hello PittsburghToast ,
