Predicta-ment revival
OK all, I do still have the Emerson on the bench, made a very major change this year (another thread) but I'm not driving a school bus anymore. I've got too many projects that need done and some I want done. Time is fleeting so this is one of my latest finds. A Predicta Pedestal. Wasn't looking for it but it found me in an antique store, looked intact and the price was fair. So it followed me home. I think it is one of the coolest Predicta sets Philco made and have hopes to bring it back to life. Mr Anderson has quite a bit of experience on these and I'm sure he will jump in here a time or two. He has a LOT of very good videos out there on various versions of these. Upon initial inspection I did find a couple cracks in the rear cover. It doesn't look like the screen cover was seated right in the strap.
I pulled the covers to see what tube was hiding in there and to hopefully test it to find the condition. Well, it IS the original 21EAP4 with the 2.38v heater. But to my surprise, it has cutoff and it tested right on the line between "bad" and "?". It's not dead by any means. Yes, I'd like to see it in the green, but a lower emission tube doesn't mean it wont produce a good picture. It will probably limit how bright it will get and how much contrast. It wont be a daily driver so if it shows a good picture, it will probably last as long as I will ever need. I did note some blue sparks when I hit "emission" with the old B&K, but I'm sure it was "waking up". No shorts. I used the Sencore afterwards which seems much nicer to the tubes. . If you watch any "Shango066" videos, you will see that sometimes he tests a tube and it shows very low, but when he brings the set to life, it show's a very good picture. I hope this is the case here.
I pulled the back off, all tubes were in place, but did have the CRT wires unplugged and (UGH) the HV lead cut. It does look like the H osc tube went to air and the H out tube also. I'm sure someone plugged it in. Death cap was blown and snipped out. So, I'll replace those 2 tubes and dim bulb it to check things. Fly looks a little melted and it has been moused some. So stay tuned for updates and feel free to jump in with comments. This will not be a rapid project as I have other things on the plate that need done over the winter.
Tim
Hello Tv Man,
Very nice I have a Princess model in my collection I had friend who had another repair shop in the area who got a Predicta Pedestal for free back in the 1980s .
Sincerely richard
Tim
You got your work cut out for ya...may the TV repair gods smile on you.
Philco 60 Power Trans
Dan; I take it that you mean that the H.V winding reads 157 ohms on one side of the center tap, and 177 ohms on the o...Arran — 07:00 PM
New find. 91X code 225
Hello, I have a Philco 91 code 121 (one speaker). I found more info here that might be of some help. Might want to fo...dconant — 06:42 PM
Hello, The HV winding on the trans is about 700 volts no load. My meter (Fluke 115) only reads to 650 volts so I meas...dconant — 04:18 PM
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM
Nice grab! It appears to be a 19X cabinet. This wasn't unusual. Philco often retrofitted to other cabinets as invento...GarySP — 12:32 PM
I would certainly write down step-by-step the progression of disassembly of the works, and probably cuss out the electri...GarySP — 12:18 PM
Nice looking! This annotated schematic from our library shows parts that are slightly different in the early and later ...klondike98 — 11:33 AM
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
