Millen 90800 transmitter
I sometimes just get these items because the alternative is the dump.
I’ve gotten a Millen90800 50 watt exciter circa 1940. I guess it will make a nice CW transmitter for SKN I guess. Anyone know anything about this? I have a copy of the manual and the 1940 QST article so that may be it.
Hope these links help looks like a fun project. David   https://www.jamesmillensociety.org/eqpicts/90800.html    https://www.radiomuseum.org/r/millen_50_..._90800.htm  https://www.qsl.net/la5ki/org/mi/90800.html
I have a hb copy of one from the QST article. Don't know when it was built maybe in the '50s or '60s. The coils are kinda hard to come across.
Peter; I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
