Greetings Phorum members,
Hope you can help me identify this type of wire in the photo I have attached.  I am not sure about the replacement type for it since it is the only rubber covered wire that I have seen thus far in the entire radio(37-640).  Thanks and Happy and S         afe Thanksgiving---John
The red wire is rubber covered wire.
The others are cotton braid over rubber often in colors or a tracer, also strand. The wire size is #20. Generally the filament wires are #18 for larger chassis #16.
In time the sulfur in the rubber rots the cotton and becomes brittle bending the wire will cause the insulation to crack and fall off.
Chas
Pliny the younger
...and modern wire of the appropriate gauges and insulation V-rating (300V minimum, usually shown right on the wire) is what you need.
Here's one source for your wire of many.
https://www.tubedepot.com/products/20-ga...olt-rating
Take care and BE HEALTHY! Gary
P.S. Can't get the right color you need? I just buy white and code it by drawing a line on the insulation from end to end with an appropriately-colored Sharpie permanent marker.
It's possible that the red wire, actually a grid cap lead, is a very old replacement, I can't remember seeing a pre 1939 Philco where they used the rubber/gutta percha covered wire for grid leads, that was more of and RCA thing. As to what to use as a replacement, well it is low voltage, and low current, but you also want something mechanically sound, so 10 or 20 gauge, stranded, would do
Thanks to all for the feedback. As Arran said, it is probably an older replacement and yes it has a grid cap so I will use cloth covered 20 gauge stranded and I should be fine.--thanks John
There are currently 1546 online users. [Complete List]
» 2 Member(s) | 1544 Guest(s)
