Motorboating/buzzing
Working on a 40-130.  Recapped it, got rid of the rubber wires, and it's been working fine.  The tuning capacitor mounts were shot, so I replaced those, and the tuning mechanism works great.  In that process, I desoldered and resoldered three wires on the tuning cap, and removed and replaced two tubes close to the tuning cap.  Turned it on, and I get motorboating with no stations under it.  The frequency increases as you increase the volume.  Where should I begin in troubleshooting this?
Is there any tube that maybe had the grid wire inside the shield and now it is outside?
Guess not...
OK. The tubes are loctals. In those you replace, make sure the pins are cleaned. Loctals reuqire scrubbing every pin with something to remove oxidation.
When I said I replaced the tubes, I meant I pulled them out and put them back in, to make room to desolder and remove the tuning cap.
OK.
Still. Retrace what you have done, and (if the tubes are the same) clean the pins.
And make sure the tubes are installed in their places (loctal bases might not keep you from swapping them).
Hello Rotolactor,
Yes, double check and tripple check plus I would make sure you hooked the grounds back up to the tunning capacitor too.
Philco 370LZ chair side not a 71LZ
I came across this post and I just redid my 370. My Question is: Where does the toner rod go. This one was in a bag a...Villager61 — 08:36 PM
My collection presentation
This will be a description of my twice favorite part of the collection. First, these are my favorite battery radios. S...Vlad95 — 06:25 PM
You probably don't have to worry about replacing transistors until you finish the recap. If you find that a transistor s...RodB — 10:19 AM
Start with recap. Address transistors only if needed. Testing transistors is simple and is best done with an analog ohmm...morzh — 09:01 AM
462ron
Hi Jeffcon, your HR-101 transistors cross reference over to an ECG-104 or RCA SK 3719 or an NTE104. It’s a PNP Ge (germa...462ron — 08:27 AM
Thanks RodB and morzh, Am I using incorrect terminology regarding output transistor question whether they’re NPN or PNP?...Jeffcon — 08:56 PM
Full recap is a no-brainer. By full I mean full. No caps, with the sole exclusion being ceramics/mica, if present, shou...morzh — 03:57 PM
This article has been updated. A tutorial on capacitor restoration has been added. How to repack an electrolytic cap...Vlad95 — 11:43 AM
Hello Jeffcon, Welcome to the Phorum. You've taken a risky step in powering up 65-year-old electronics without having...RodB — 10:49 AM
This is a nice little Motorola set that appears to be in relatively good shape. None of the external plastic case is br...klondike98 — 01:36 AM
There are currently 1681 online users. [Complete List]
» 2 Member(s) | 1679 Guest(s)
