Eico 232 VTVM Schematic
A friend gave me this Eico 232 VTVM and I'm having trouble locating the schematic for it. This one seems to be a later version because it has solid state diodes to replace the 6AL5 duo diode tube. I would say maybe early 60s. All my searches have resulted in the schematic for a 12AU7 and 6AL5 configuration. This one has only a 6FQ7/6CG7 replacing the 12AU7. Any help is appreciated.
Is that a battery holder?
Try BAMA for a schematic.
Looks like a replacement power source for the D battery has been installed. The tube may be a sub for the 12AU7. As long as it balances and is stable should be fine.
Was the Uniprobe provided?
Chas
Pliny the younger
It's a microwave antenna. ?;-p?. I substituted 1N4002s off the 6.3 vac winding for the 1.5 volt battery. Uniprobe is there. BAMA has the older schematic. I haven't looked up the tube yet, it has two sections but it's a 6 volt tube. I guess I'll wing it for now.
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:25 PM
Testin a speaker and output transformer Trutone A2-G
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:24 PM
Save the money on the Kapton tape. Just cut an insulator to size out of a clear plastic blister pack and attach it arou...GarySP — 01:13 PM
The thing is when I touch or probe the antenna terminal, the volume control input, the wiper (output), and the primary t...Stormlord5500 — 12:53 PM
Two small radios from France. Restoration and review.
Hello, Vlad. I agree with your description of French radios. I might add that they are made like French cars – extravaga...RadioSvit — 11:08 AM
I do thank you all for helping me out on this.Stormlord5500 — 08:01 AM
It does oscillate. Here's the deal. If I touch a probe or my finger to anything in the secondary circuit of the antenna ...Stormlord5500 — 08:00 AM
Hello Arran, Some great info so you are talking about silver migration then that seems to really play issues with these...radiorich — 02:43 AM
Hi Stormlord and welcome to the Phorum. I am scratching my head because, even if the primary of the antenna coil is b...MrFixr55 — 01:56 AM
You do not have to use Kapton: buy a bottle of fabric glue and simply put a thick layer to fix the turns.morzh — 04:04 PM
There are currently 2196 online users. [Complete List]
» 1 Member(s) | 2195 Guest(s)
