Model 37-84 BUZZ?Humm?
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked many grounds. Changed & tested tubes,usual voltage checks, removing 6j7's an still have buzz/humm.Running short on ideas!
Thank everyone for any direction resolving
Bruce
Correct on model ID 37-84 NOT 27
Finally after 50 plus years I'm back into the hobby again. It's like trying to relearn a second language some of it makes sense and some of it doesn't! Could be fun now considering my son is now into old radios and tube technology!
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch input to amp or is it a hum ?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap connected to the center tap of the high voltage winding, and the other to chassis, with a series of wire wound resistors in-between. It's a common mistake a lot of people make because they are used to working on 1940s and 50s radios that have the tubes cathode biased rather then fixed bias, so in effect one filter cap is open circuit if you connect both to the chassis.
Depends on the type of hum. SOme is made by outside devices.
Try installing an X-cap (0.2-0.5uF) across the AC line, while still keeping the Y-cap (yours is 0.015uF, I think) where it is; also try to see if inverting the plug position 180 degrees affects it.
You do not have to use Kapton: buy a bottle of fabric glue and simply put a think layer to fix the turns.morzh — 04:04 PM
I have to get the 44 awg wire and I'm thinking of using kapton tape to wind on. I don't have the tape either. Money is s...Stormlord5500 — 03:05 PM
Michael, I would be very happy to buy this "piggy", but it is not for sale yet. :cry:RadioSvit — 02:38 PM
Arran. Once again, thank you very much for the interesting information.RadioSvit — 02:36 PM
Peter; Hallicrafters radios had an excellent reputation during the war years, and up until the mid 1950s on their com...Arran — 02:16 PM
Не було в баби клопоту, так купила порося. :lol:morzh — 01:53 PM
Superior 450 schematic
If anyone has one of these i need interior pics especially The bottom of the tube socket. Thanks.daveone23 — 11:52 AM
What happens if an old radio collector gets an old gramophone for restoration? A collector of old radios also becomes a ...RadioSvit — 11:22 AM
Arran, thank you very much for sharing your experience again. I will take this into account when I do the alignment of t...RadioSvit — 08:59 AM
I have never seen anything other than instructions and data for the 450/450A.DaleHCook — 07:37 AM
