46-1201 Turntable issues
Hello, first post here, bear with me.
I've been electronically refurbishing a 46-1201 that I received from a relative. I got it to power on, selected phono, and the turntable spun, but it wouldn't stop whether the door was open or closed. Looking inside, it appears the trip release spring, the part that actuates the mercury switch, had snapped off a long time ago, and I can't seem to find a replacement, nor am I equipped to make one. could any of you Philco gurus help me out? The model of turntable mechanism is the M-7.
Here's a Photo.
Thanks!
-ConcernedFeller
I deleted the other thread, as it was duplicate and did not have the photo.
Please proceed with this one.
The speaker table error?
G  10-1/2"       65, 76, 87, 95 Push-Pull 45's 2766 0.7 550 3200 H   10-1/2"    77, 96 Push-Pull...morzh — 09:26 PM
A Marconi model 86
I have a Stromberg, one of the early ones, seems early 30s. This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM
A Marconi model 86
A backbreaker.....PaulPaul Philco322 — 08:12 PM
A Marconi model 86
>>What a behemoth! A Juggernaut.morzh — 07:47 PM
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM
A Marconi model 86
:e_biggrin: What a behemoth!  I hope the final result is as much a quality sounding example!  Keep us posted on your pro...GarySP — 07:32 PM
A Marconi model 86
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM
Philco model 60
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM
A Marconi model 86
Dan Double conversion is using two IF converters instead of one. This improves the image response. morzh — 07:15 PM
