40-190 part
Hello I am new to posting,
I am looking for information on a part in this radio. I am posting a picture of this part shown in the blue box. I can not find this on my print either.
Thanks in advance,
N9BQA
Either a resistor or a cap.
A closer take with legible marking could help.
I have added 2 more pictures of this part.
My vote's for resistor. Try measuring resistance through it.
Also, looks like it's attached to a tube pin. Check the schematic and see what's attached to that pin.
Can't think of anything witty.
Greg O.
Whitehall, PA
I also think it is a Micamold resistor.
hello Guys,
Yes, If you measure it with a meter I am also sure it is one.
Thanks guys for all your help with this.
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
There are currently 1230 online users. [Complete List]
» 2 Member(s) | 1228 Guest(s)
