Hello guy's,
Have a Trutone A2-G teledial floor model radio that I am having issues with.
Suspecting maybe speaker or output transformer.
This speaker has a 5 pin connector, so I am not sure how to check it with my ohm meter. Used to 4 oin connectors.
Problem I am having is volume issues. Plays fine at lower volumes and goes south after mid range on the volume control.
Has been recapped and the transformer was replaced by previous owner.
Cadohm resistor is replaced as well as a handfull of resistors.
How do I check the speaker and output transformer on this 5 pin connector.
Tubes have all been verified as OK on my tube tester(Hikcock).
Checked voltage on rectifier tube and it is checking about 285v.
Checked on speaker socket and its about the same.
Idea's without getting to technical?
murf
Sorry Murf, technical is what I do.
OK, Unlike the Western Auto Tru-Tones, this True Tone is a Wells Gardner set. The Nostalgia Air schematic is below:
http://www.nostalgiaair.org/PagesByModel...023515.pdf.
Unfortunately, they do not show the pinouts for the speaker plug. if all 5 pins are used, the pins (IN NO PARTICULAR ORDER) would be connected to:
Plate of one 6F6
Plate of the other 6F6
Center tap of output transformer and one leg of the field coil
Other leg of field coil
Chassis ground
If you take out the 2 6F6 tubes and ohm between pin 3 of one 6F6 and pin 3 of the other 6F6, there should be about 560 Ohm. Lift one leg of the secondary connection to the speaker voice coil. Resistance of the secondary, the voice coil and the hum bucking coil all should be quite low. I suspect that these resistance checks will pass and that your issue is elsewhere. My bet is that the wrong power transformer was used or there is an issue with the voltage divider (resistors R22, R23 and R24) that produces "C-".
One possible issue is that your B+ (from rectifier cathode to ground) of 250V is quite low. The schematic lists plate voltage to ground at the 6F6 plate (pin 3 of each 6F6) is 330VDC. The center tap of the rectifier connects to ground through resistors R22, R23 and R24 (the Candohm?) This develops the grid bias (C-) for the Output tubes, 1st AF and Phase Invertor (Balancing Excitor). There should be about -25V between chassis ground and the center tap of the power transformer. Measuring across C44 should yield about 355V. Note that t5h3 can case of C44 does not connect to Chassis ground, it connects to the junction of R24 and the HV Secondary center tap of the power transformer. This point, not Chassis Ground is the most negative point on the power supply. Note that the cathodes of the audio amp and outputs are at Chassis ground, but the 6F6s require a bias of about -25V for grid bias. This is taken from the junction of R24 and they HV secondary center tap.
If R22, 23 and /or 24 change resistance with high current, this may cause your issue. Low B+ (250Vvs 330V) will cause the same issue.
Hope this helps.
Any reason for the 2nd copy of the thread?
Hi Morzh,
From my end, no. I did not know that there are 2 threads on this topic. Maybe it should be combined.
MrFixr
Honestly, I haven't done that yet and do not want to screw up the threads; maybe you could do it, or we could ask Gary or Nathan, or Bob.
Sorry, my mistake.
murf
Thanks for the replies, I will check these ideas out and report back.
murf
Well I have found 315v on the rectifier when cold. Drops off to 280 after 15 minute warmup.
Checked pin 3 on both 6F6 tubes and found 280v when cold and 250v after 15 minute warmup.
THis is probably whats causing the low volume and distortion after a good warmup. Now I am guessing that I will be needing a power transformer? Will check again and verify my readings.
murf
The transformer may be the last cause of voltage drop.
This level of voltage drop is not too big. Conduct additional testing at maximum volume. If the voltage drop is more than 30V from cold, it may be the cause of low emission of the rectifier tube. Try replacing it.
I have encountered similar problems on several of my radios.
Check voltage on rectifier 5Y3G catode, not on pin 6F6  when volume is on .
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - Gary
Would an output transformer if weak, cause the problems I am seeing with lower B+ voltage?
murf
Hi Murf,
Do this:
Monitor between ground and one plate of the rectifier while playing the radio.  Do the same with the other plate.  If your meter can measure a high enough voltage, measure across the plates.  CAUTION!!  This is about 750 Volts or so.  If no voltage drop from start until distortion occurs, then the power transformer is good.
While radio is playing, especially when the distortion starts, observe the 6F6 tubes for "red plate" or any abnormal glow between elements. (Hopefully they are not metal).
Power down, unplug and immediately feel the transformers.  Feel the caps, C44 and C43.  Likewise, the speaker field coil.  They may be warm but not hot.
What voltage rating did you use for the filter caps?  Fr C44 in particular, ensure that you used either 450 or 500 WV (Working Volts)
You can measure the current draw by placing the meter between the 5Y3 cathode and the rest of the circuit.  If the current increases with time as the B+ voltage drops, then suspect a component shorting.  If the current decreases as the voltage drops and the AC output of the HV winding of the power transformer did not change, then suspect the rectifier or the B- C- resistors (R22, 23, 24).  You can also measure the DC voltage drop between the chassis ground and the HV secondary center tap.  If this voltage increases with time when the distortion starts, then these are your culprits.  Ensure that you used sufficient wattage.  At least 5 W, preferably 10 or 20W.
I do not expect that output transformer to be the issue.  They either work or don't.  I don't think that it is shorting as it gets warm.  It is possible, but I don't think probable.  The speaker frame (and therefore the output transformer frame and field coil frame) are grounded.  If a ground develops, there will be a lowering of B+ along with a B current increase.  However, there would be smells, burning, etc. if intermittent grounding of transformer and / or field coil windings is occurring.
Hope this helps.
I am not sure how a transformer could be weak. It could be inadequate, but only when you replace the original with something inadequate; the original transformer cannot become weak.
It could gen an open; it could get a turn short, both of which will render it inoperative. But not weak.
morzh
Short-circuited turns can be considered as a half-dead transformer.
But on this case transformer will hot and smell.
On this particular case in 90% bad rectifiers emission , as I mention above.
I've never had an output transformer become shorted, the failure mode is usually an open primary, or in a center tapped one, one leg of the primary could become open whilst the other may still show continuity. The set will still play like this, but not as loud, and possibly with more distortion, I don't think it would cause overheating as the other output tube is basically removed from the circuit. Now a leaky tone correction cap can cause major issues, this is usually why I clip them out when powering up a set for the first time, in some cases they can cause a dead short across the B+.
The equivalent of one short turn is basically the same as that of a shorted load.
If it is the primary's turn, then the load is the loss resistance of that turn, which is just a smidge higher than would be the loss of a turn of the secondary, due to large output winding's wire's diameter.
If supplied with the signal, it will induce current in it and cause heating.
If not (just the DC bias is applied, but no AC component is present), then the transformer will not heat up anymore than as if it were OK. That is the resistive losses in the primary.
The shorted load (if it is the secondary) will cause a total short, as it is close to a milliOhm or so. If in the primary, it could be close to 0.05 - 0.1 Ohms and is comparable to early speakers' voice coil resistance, so there will be a little (very little) signal coming out. Plus heating/smoking etc, if the signal is strong.
You guy's are right on. I found a broken wire on the speaker plug that I replaced and all is well now.
Have better volume and my B+ is reading 315v consistanly now.
Working well and back in its cabinet now.
Thanks to everyone!!!!!!!!!!!
murf
