Crack In Philco 50-920 Plastic Cabinet
Threads: 55
City: Roseville, MN
I'm working on restoring this 50-920 and would appreciate some help deciding how to repair this 7-1/2 inch crack that runs front to back on a corner. My thought is to secure the crack with super glue, fill the crack with JB Weld PlasticWeld, sand smooth then stain or paint. Maybe run a line of JB along the inside of the crack. By then the cabinet should weigh another pound heavier.
Threads: 23
City: Greenlawn
State, Province, Country: NY
Hi Rod,
Search the Phorum for the following thread by Ron Ramirez (God rest his soul):
The Story of the Broken 38-12CB
this was a plaskon radio but I suppose that the techniques for repair would be similar for bakelite.
For this case here, I am in full agreement with trying to spread the crack a little and wick some Krazy Glue into the crack. I also agree with JB Weld on the inside of the set to further reinforce. \\The outside surface is a big question mark. I don't know if JB Weld is the best for the visible surface. I wonder if Bondo or some other auto body filler would be easier to work. The final issue is finishing the cabinet. This set has a natural bakelite finish. The set that Ron had repaired was painted white. The Bondo repair job could be sanded smooth by stepping from a 200 grit paper through 400, 600 and up to 1000 grit wet sandpaper, similar to dent repair on a car, but then one has to paint the cabinet, losing the original finish.
I would use some two part epoxy, the clear stuff that takes 24 hours to harden, and work it's way into the crack from the backside, if you can spread the crack before you do this it would help. I don't like C.A based glue because it tends to break down with age, and J.B Weld is metal filled, which is not really what you need here. This will make the crack as close to invisible as possible to start with, you don't really need to plaster the inside of the cabinet with anything, I never have with a straight crack, and have never had a bond fail.
(This post was last modified: 07-01-2025, 11:34 PM by Arran.)
Threads: 226
City: Omak
State, Province, Country: WA
Hello Rod,
I too agree with Arran,
Threads: 164
City: Westland, MI
One suggestion I would offer is to get a brown Sharpie permanent marker and color in the cracks to help hide after the epoxy is applied. I would get a shade or three of different brown markers to see which blend best. Use a pliable small putty knife to apply the epoxy from the inside-out. A credit card is a close second choice. Do your best to push as much glue through to the outside. You might consider wrapping a Bungie cord around it 4-5 times to put some compression on the crack. Use stand-offs on each side of the crack under the cord to keep it from gluing to the cabinet. Two dowel rods, one on each side of the crack will keep the cord out of the glue. Good luck! Take care, - Gary
Threads: 23
City: Greenlawn
Great ideas, Garry!
Threads: 55
City: Roseville, MN
Yes, thanks everyone. I'll be putting together a plan and when I have it done I'll report the results.
Threads: 55
City: Roseville, MN
Here is my process.
I decided to use the idea of a couple bungee cords with wood spacers to keep the cords away from the crack and adhesive.
I had purchased slow set, clear epoxy and mixed a batch, cleaned the inside and outside of the crack with alcohol, secured the crack with the bungee cords then laid a line of epoxy along the inside of the crack. Next, I used the blade of a screwdriver and forced epoxy into the crack. A day later the cabinet is now solid. I mixed a small batch of epoxy and with a toothpick filled in the open sections of the crack. I could keep filling but it probably won't look much better than it is now. Certainly a scar but what's wrong with some character?
I'll post a final photo when all is assembled.
Threads: 7
City: SPRUCE GROVE
State, Province, Country: Alberta
Good result. I think that if you now grind the crack #400 -> #600 -> #1000 and then polish it, the crack will almost disappear.
If you want to work, lie down and sleep, and everything will pass.
Threads: 55
City: Roseville, MN
Finished up this project yesterday. Six tube AA6, plays nice, looks nice. Didn't go any further with the crack. Had a tough time remembering how it went back together, turned out I was making it more complicated than it was.
(This post was last modified: 09-11-2025, 09:54 AM by RodB.)
Threads: 437
City: Boston
I have done the bungi routine before, it can work pretty good. I kinda like those Sunburst type dial on top. 6 tubes good enough for use around the house. Paul
| Ok guys. Thanks for the input. As for AI this is why I ask the experts.
Dandconant — 07:39 AM |
| Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM |
| hello Roy,
I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM |
| This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM |
| Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM |
| Roy;
Personally I would have left the asbestos alone if it were my set, but you can find a modern substitute that som...Arran — 04:51 PM |
| Looks like that might be the B- buss, so that would be correct.RodB — 01:32 PM |
| I noticed on the code 121 schematic the center tap for the 6 volt winding and hv winding are tied together. Is this corr...dconant — 12:16 PM |
| The Philco Parts Catalog for 1942 shows it as usable for 175 kHz, 260 kHz, and 465 kHz. The instructions will show how t...DaleHCook — 11:19 AM |
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
