41-327 retouching black paint
This has missing paint chips on the case. Would you just use a black laquer stic on this? Otherwise the case is in good shape so I don’t to refinish it all.
Yes, and you'll be amazed at the results.
Ok. I ordered one of those this morning.
If the lacquer stick doesn’t work out it’s not that big a job to remove the chassis, mask off the black, lightly sand and respray with black lacquer.
Actually I got that in and used it this morning. Seems to work very well.
Do you just let it dry and then use wax on the cabinet or something else?
I have just been cleaning with the non abrasive Goop, using some feed n wax followed by two coats of Johnsons paste wax.
Yes I just let it dry. I would let it dry for several weeks before waxing as lacquers can take quite awhile to fully cure. I've used both the Feed n Wax product and paste waxes. Its more a matter of what you want the end sheen to be.
Hello guys,
Yes, I have used a laquer stic on furniture never on radio yet .
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
